RV Sat/Cable TV Input location
riverruby
:( I have a 98 Damon Intruder Class A and if anyone has a similar model that could advise me as to where the input hook-up is located. The cable terminates in a cabinet along the side of the overhead TV. From there it just disappears into a black hole in the wall. I think it is a factory option. Help, I do not want to drill a hole in the wall if I do not have to. I would think it would be on the utility side of the MH>?
Re: RV Sat/Cable TV Input location
I assume that you are looking for the place to connect your TV to an RV park's cable TV signal? Most likely it is in the same bay as your shore power cord is stored in, but that is a guess. I am sure that it is in one of the storage bays. It will look just like the standard screw on connection as you would find on the wall of a house. You will need a cable with a female connector on both ends to use it.
riverruby
thanks Kirk, I have went thru a box of batteries with my flashlite looking there and underneath the RV.
