HELP!!!
I have a 1983 37 ft class A on a chevy 454 platform made by a company called 'The Establishment'. I have a wire some idiot connected to a cylinoid mounted on the passenger side of the engien compartment all the at the top. This wire goes to my radio. I double checked to make sure it goes no where else. Found someone rigged it up with 3 connections. One is some aftermarket wire going to the radio. 2 goes to the power side of the cylinoid above the engien. 3 goes deep into the firewall. I can't seem to turn the ignition on now. When I use a power probe on this wire I hear a click from a second set of cylinoids in the front compartment that is mounted on the same wall the radiator sits on and all the lights come on, and so does the ignition when the key is turned. What is going on?
