shocked when touching metal on RV
Hello,
Agree with the reverse polarity comments.
There is a possibility your primary cable has been replaced and the hot and neutral (not ground) have been switched at the connection in the trailer.
It may be nothing more than swapping the 2 wires (usually black and white) at the entrance connection. The black should be on the line side and white on the neutral. If there is a 3rd wire (which there usually is) it should be green and grounded to the trailer.
I would be curious to know if you were standing on concrete/wet/asphast/dirt and were bare footed when this happens?
You may be able to test this condition by wetting an area on the ground (duplicate the condition that made you recognize the voltage) and using an ammeter/test light between the trailer/metal and the wet ground area - if you get a reading or light, you have voltage and a problem. If you swap the wires and duplicate the test and no light and things still work, you know what the problem was.
Bruce
Thats my guess...
Bruce A. Wittmeier
Home:
MikeBrandn@aol.com
2001 Ford F250 PSD, Ext cab, Shortbed, Island Blue/Silver, 4X4 Off-road, SOF Auto, Alum Wheels, Chrome Step, Line-X bedliner, Reese 16K slider, Jordan Ultima 2020, AirLift Airbags, Sunnybrook 30RKFS
Edited by - wittmeba on Jun 06 2002 01:06:07 AM
