Solar Panel trickle charging
Tony A
I have a class C Majestic that has a roof top solar panel trickle charge system, it has a small red LED light that informs you that the panel is charging the battery. the LED will no longer illuminate and the battery no longer maintains a charge when not in use. anyone have experience in repairing or replacing the roof top solar panel?
Thanks
Grub54891
I'd start with the battery itself, have it tested to see if its any good.
Them small solar panels charge real slow, many it couldn't keep up to the usage, look for fuses that are blown, and check all the wiring connections. You can use a multimeter to check if its actually working.
