Solar
TexasClodhopper
Re: Solar
First, add up the absolute minimum and absolute maximum wattage that you think you would need to consume.
Second, look for a solar generator that can supply that.
Third, bring lots of money. It won't be cheap.
Re: Solar
You can not go 100% solar, hot water, cooking and refer still take propane and heat if needed. For electrical needs for TV, computer, lights and coffee in the morning and the furnace once in a while 300-400 watts $2000 to $3000 will do it, if your in open area and good days of sun.
alapataws
Re: Solar
Thanks for the advice Tex and Len. I had budgete about $5k for the project so it's sounds like I can do this. I was going to use LP for the appliances you noted but was thinking about converting some of them either to DC or AC with an solar inverter. I have seen this done to off-grid cabins and thought it could apply to TT as well. If not the LP works for me. I was also thinking about installing LED lighting?
Thanks and God Bless,
J.K.
