stinky problem
#1
To the experts out there, I have a small problem that I think it might get worst. So here my problem: my commode some time backs up, wefill the bowl with water before each use and give it a good flushing, plus we let the water run awhile, but it still backs up after awhile. I get out the old hose and put in the bowl and flush it until the blockage is gone. The next day or two we run into the same thing. So is there something that we are doing wrong,or am I looking into a stinky repair situation . If so Rod you want it to repair?:laugh: :laugh: :laugh: . Just kidding Rod. any suggestion on what my problem might be?
DL Rupper
#2
Re: stinky problem
Hey Hollis, maybe you are eating to much fiber. Just kidding. :laugh: :laugh: :laugh: Seriously, are you putting a few gallons (5/6) of water in the bottom of the holding tank before you use it?
#3
Re: stinky problem
Hey Hollis...I fill the bowl 5 or 6 times which may be over kill but I don't want your problem. Are you using single ply tp?
#4
Re: stinky problem
Hey Jim we do fill it up before use it and AFTER flushing it we let the water run to further clean it. Also we do use the single ply nothing else.
DL what do it matter if there is 5/6 water in the holding tank :( ? We don't leave the knife valve in the open position. we keep it closed until the tanks is about 3/4 full then we empty it and then flush it with the gray water. this passed trip I hook up the extra hose and flushed the black tank before I closed the valve.
#5
Re: stinky problem
What I meant was I fill the toilet bowl 5/6 times after I've drained and closed the black tank valve. It gives plenty of liquid so the other "stuff" doesn't "pyramid". I don't use any chemicals either, not that that would have anything to do with your problem.
#6
Re: stinky problem
Jim now I understand what you was saying. I back flush the tank each time I empty the tank. I can't imagine a pyramid effect taking place and I was under the impression that with all that water going down at one time would flow all waste down to the holding tank and the extra flushing water just cleans the pipes that dumps into the tank.
#7
Re: stinky problem
Hollis, Put about 15 gallons of water in your tank, then put a bag of ice in it. Drive around some and flush that out. Bet you find it won't be clear. We find a lot of "pyramids" in tanks that people swear they get it clean. The ice will break it up and clean it out.
G
Guest
Guest
#8
Re: stinky problem
Hollis ,, can u see down thru u'r toilet ???? i can on mine ,, i see right to the bottom of the tank ,,,, but i would do as ken say's ,, see if the ice don't break it up ,,, but don't put the bag and all in there ,, just the ice ;) :eek: :laugh: :laugh:
#10
Re: stinky problem
Now thats a new thing to compete in-----------------Who's got the biggest turd pyramid before breakup in the spring. LOL
#11
Re: stinky problem
Rod I have what looks like a 45 degree offset in the piping heading to the tank. I was able with a bright like see some blockage of paper and I was able to clean that out of the pipe. This Sat morning I am going to do the ice trick that Ken has suggested and see it that helps. I will post back my results. Thanks everyone for the help.
DL Rupper
#12
Re: stinky problem
Hey Hollis, you need about 5 or 6 gallons of water in the bottom of the holding tank before you ever use it. That stops the the stinky stuff from starting a pyramid by sticking to the bottom of the tank. :dead:
#13
Re: stinky problem
YES I know that now DL and will be sure that takes place on out future trips. Also thanks for the info very helpful
utmtman
#14
Re: stinky problem
I had a HR trailer that would plug up nine times out of ten uses. The line did not drop strait to the tank like my motor home does. It bent 45 than down and I swear back another 45. I had to buy a small wire snake one of the flat straight wire types to help me clean it out and HR dealer told me that was normal.
Good luck to you hollis, I hope you can get it worked out.
DL Rupper
#15
Re: stinky problem
I just found a new stinky problem. The RV park we found was really a great bargain. It was GS for sat/sun ($28/night) and then we got Passport America for 4 days ($14/night). It even has free cable and wifi. Great. Except there are lots of sewer line vents sticking up in the air (about 10 to 12 feet). Well the methane fumes keep blowing in the RV from the vents. It's too hot, about 75 degrees, to close the windows and not really hot enough to turn on the air condition. Woe is me. :eek:
DL Rupper
#18
Re: stinky problem
Well the smell went away later yesterday. Hope it stays away as we will be here 5 more days. Those sewer vent pipes lead me to believe it will be back before I leave here.
