Hey folks,
I just tried to turn my furnace on and it does the following:
1. Turn on on/off switch
2. Set Thermostat to 72 degrees
3. After about 30 seconds, the blower fan comes on but no heat. In the past the heat would come on FIRST and then the blower would come on and all was fine. Ran the furnace one or two nights back in early December but not since then. Just filled the LP tank yesterday.
I've checked the thermostat, cleaned the main contact to thermostat and blown out the thermostat with compressed air (can for PC). I've read that it might be air in the line and to bleed the line, but I'm not sure how to do that....the water heater works fine.
We are not gonna freeze tonight, since I have an electric heater that is plugged in, but will be heading north on MOnday and want to make sure the furnace works if I need it there.
Any ideas as to what might be the problem, since it worked fine in Dec but not now????? :dead: :sleepy: :disapprove:
