Re: Surge Protection
Kirk - 5/14/2009 7:08 PM
I have no idea where the previous post got his information, but it sure don't agree with what I learned in my electronic education, nor with my experience of working forty years in electronic service?
One who designed surge protection knows surges are measured in current - not voltage. Voltage will build a plasma path that can conduct the surge. But the surge itself is a massive current source (not a voltage source). Voltage only exists (increases) where something tries to stop that surge. No voltage means no energy. Franklin demonstrated the concept in 1752.
Lightning strikes a wooden church steeple because wood is conductive - a connection to earth more conductive than air. But since wood is not sufficiently conductive, current must create a higher voltage. Therein lies destructive energy in a surge. Voltage increases, as necessary, to conduct that current through wood. Voltage times current is more power (and energy). Divert that current on a more conductive material - no voltage; no energy; no damage. An insufficient conducting church steeple means voltage, destructive energy, and damage.
Franklin solved this problem by simply connecting lightning to earth on a more conductive path - a lightning rod. Same surge current. But no voltage and no energy dissipated destructively. Instead, energy dissipates harmlessly in earth. Earth always provides protection - as was standard even 100 years ago. This is basic circuit theory taught first year engineers.
Either a surge current flows destructively through an appliance - creates a high voltage destructively inside the appliance. Or current flows directly to earth via an earthed protector - near zero voltage and near zero energy. Just like Franklin's lightning rod - surge protection means conducting a surge harmlessly into earth with near zero voltage.
Many surge protectors exist. In reliabile facilities, earthed protector is the only 'always required' solution. A solution that has been used for 100 years is the same principle demonstrated by Franklin in 1752. And still some have failed to learn these well proven principles. Some foolishly believe a 2 cm part will stop what three miles of non-conductive air could not. Even a technician did not do what is required to have that knowledge. He should post those manufacturer specs numbers that define protection. No such protection claims exist. How would an experience technician then *know* it must work? It is often a problem for engineers. Technicians who know without first learning.
Those missing specs are why telcos everywhere in the world do not use nongrounded protectors. Current increases voltage, as necessary, to blow through any protector that would absorb surges. Where is that spec for protection? Does not exist.
Why does every telco CO connect protectors as close to the earthing electrode as possible? Why do they prefer protectors to be located farther from electronics? Same reason why it also works for an RV.
As Franklin's lightning rods demonstrated, if a surge current gets connected shorter to earth, then near zero voltage exists. Near zero voltage times 20,000 amps means near zero power (and energy). A surge current that does not enter the RV does not create voltages; does not dissipate energy destructively inside the RV. Energy (current) that does not enter an RV will not cause damage which is why the effective protector have a dedicated wire for earthing.
