Thor Travel Trailer Floor/Leaks
par0hd
Hello Everyone!
We have a problem with our 1999 Thor UD19 travel trailer. The floor is rotten from the front to about midway through the camper. The back wall also seems to be getting water in it.
Has anyone else experienced this with a Thor model?
Thanks....
Welcom to the forum parOhd. Sad to say this is a fairly common problem with rvs :( . More than likely you will find a bad water leak in the top somewhere or a window. Does it have the rubber roof? Really should inspect the tops every couple months and reseal every joint or seam often. Maybe some Thor owners will give you better insight as to where and if they have had problems with this.
