Sharkysocal
My 79 Dodge Sportsman, 24' Model Beaver has a GVWR of 11500 lbs.
I Just bought it, and had Americas Tire put on the same tires it has specified on the door sticker. 8.00X16.50
Only I changed from Bias ply to Radial.
The tires are rated at 2040 lbs per tire. Thats only 12,240 lbs of weight.
This only gives me 500lbs to load the bugger with.
The tire shops I spoke with said I should be fine loading more then 12240 lbs on the RV because my tires are Load Range D. 8 ply.
I can see us loading an additional 1450 lbs not counting a future small trailer that will haul my dirtbike and firewood and a large cooler.
Can anyone please give me some advice here.
Should I ask Americas tire to switch out the tires and get the next size up, which would replace my 8.00R16.5LT/105/ N /2040 lbs with 8.75R16.5LT /111/ N / 2405 lbs
Below is a link to the Cooper tires I am talking about. Thank you in advance.
http://www.coopertire.com/html/products/tires_lighttruck.aspx?page=srm_2_radial_lt :question:
