Torque Converters
You could see a reduction in cruise RPM. It all depends on what the stall speed is of the stock converter, cruise RPM and overall condition of the stock converter. Motorhomes, from what I've seen, usually have a 4.10 gear. So your cruise RPM will be around 3000rpm @ 65mph. You'd need to calculate your theoretical RPM and check it too the actual RPM, that would be you "slip" at cruise speed. A good converter should only have around 200 rpm of slip if it's really loose you could see 500 rpm of "slip".
This is easy to see in a trans with a lockup converter. The converter in my '00 6.5TD/4L80E only drops 200-250 rpm when the converter lockups up under load. My Dodge/Cummins drops 500+rpm when it locks up. The converter in my Dodge is very loose and not in a good way, it has alot of internal fluid bypassing. Since you don't have a lockup converter you need to calculate your RPM to see roughly how much slip you have. If you only see 1-200rpm then a "lower" stall converter won't do you much good. Also with the tach you can see how much your RPMs go up when increasing the load. Watch the RPM while cruising on flat ground then maintain same MPH going uphill and see how much the RPM changes. A tighter converter will have less RPM increase than a loose one.
Hope this helps.
Dan
