Re: Towing Question
First of all, the trailer weight that you have to work with is the GVWR, which is the loaded weight, since you are not likely to tow if much with nothing in it. In this case that comes to 11,060#. The alternative is to load the trailer as it would be when you travel in it and then take it to a scale.
You can get a rough idea by comparing the towing capacity of your truck to the GVWR of the trailer and that will tell you no. With a fully loaded travel trailer you would exceed your max. towing weight by 1760#. Another way to approach the issue is to weigh your truck as it will be when towing. You many not be loaded to the GVWR of the truck, but without a scale ticket you should assume that you will be. If you have the actual loaded weight of your truck, you can then subtract that weight from the gross combined and the difference being you safe weight to tow, as long as it does not exceed the limit for towing.
In short, if you tow this trailer and keep within the manufacturer's limits, you will only be able to put a maximum of 2000# inside, including water, waste in the tanks, propane and everything for travel. You could do this, but you would need to be very careful about the weight when loading for travel and you should weigh the trailer after it is loaded to be safe.
A better idea would be a lighter trailer where you can tow the full GVWR of the trailer, or a bigger truck.
