Towing requirements
bigfink14
Junior Member
I currently have a 2009 Dodge ram 1500 with tow rating of 10.400# & payload rating of 1600#. I currently pull a 27' travel trailer with a GVWR of 7900#. Can I switch to a 5th wheel with the curent truck if I stay within the max axel rating?
toyzrus
Junior Member
Where did you come up with your numbers they don't seem right for a 1500. I have a 2012 hemi and my tow is 8650 and payload is 14 something. I was towing a fifth 26' weighing 5640 and just bought a 30' which weighs 7360 and pin 1210. Make sure you have the correct numbers for your truck.
Think you will find that the truck will handle a 5th wheel of the same weight much better.
Grandview Trailer Sa
Your right Nash, but I don't agree with the numbers the poster gave either. We had a customer the other day with a 2008 Dodge HEMI the other day, his truck was rated around 8,000.
toyzrus
Junior Member
I hope this helps.
2009 Dodge Ram 1500 Quad Cab - TOWING CAPACITIES & PAYLOADS
Quad Cab 4x2 - ST
Engine
Trans Type
Trans- mission
Axle Ratio
Payload
Base Weight
GCWR
Max Trail
3.7L V6 (EKG)
A4
42RLE (DGV)
3.92
6,700
1,810
4,863
8,500
3,450
4.7L V8 (EVE)
A5
545RFE (DGQ)
3.55
6,700
1,730
4,946
11,500
6,350
4.7L V8 (EVE)
A5
545RFE (DGQ)
3.92
6,700
1,730
4,946
12,500
7,350
5.7L V8 (EZD)
A5
545RFE (DGQ)
3.21
6,700
1,680
4,992
11,000
5,800
5.7L V8 (EZD)
A5
545RFE (DGQ)
3.55
6,700
1,680
4,992
13,000
7,800
5.7L V8 (EZD)
A5
545RFE (DGQ)
3.92
6,700
1,680
4,992
14,000
8,800
Quad Cab 4x2 - SLT
Engine
Trans Type
Trans- mission
Axle Ratio
Payload
Base Weight
GCWR
Max Trail
4.7L V8 (EVE)
A5
545RFE (DGQ)
3.55
6,700
1,660
5,017
11,500
6,300
4.7L V8 (EVE)
A5
545RFE (DGQ)
3.92
6,700
1,660
5,017
12,500
7,300
4.7L V8 (EVE)
A5
545RFE (DGQ)
3.55
6,700
1,610
5,060
10,500
5,250
4.7L V8 (EVE)
A5
545RFE (DGQ)
3.92
6,700
1,610
5,060
11,500
6,250
5.7L V8 (EZD)
A5
545RFE (DGQ)
3.21
6,700
1,610
5,063
11,000
5,750
5.7L V8 (EZD)
A5
545RFE (DGQ)
3.55
6,700
1,610
5,063
13,000
7,750
5.7L V8 (EZD)
A5
545RFE (DGQ)
3.92
6,700
1,610
5,063
14,000
8,750
5.7L V8 (EZD)
A5
545RFE (DGQ)
3.55
6,700
1,570
5,106
12,000
6,700
5.7L V8 (EZD)
A5
545RFE (DGQ)
3.92
6,700
1,570
5,106
13,000
7,700
Quad Cab 4x2 - LARAMIE
Engine
Trans Type
Trans- mission
Axle Ratio
Payload
Base Weight
GCWR
Max Trail
5.7L V8 (EZD)
A5
545RFE (DGQ)
3.21
6,700
1,610
5,063
11,000
5,750
5.7L V8 (EZD)
A5
545RFE (DGQ)
3.55
6,700
1,610
5,063
13,000
7,750
5.7L V8 (EZD)
A5
545RFE (DGQ)
3.92
6,700
1,610
5,063
14,000
8,750
5.7L V8 (EZD)
A5
545RFE (DGQ)
3.55
6,700
1,570
5,106
12,000
6,700
5.7L V8 (EZD)
A5
545RFE (DGQ)
3.92
6,700
1,570
5,106
13,000
7,700
Quad Cab 4x4 - ST
Engine
Trans Type
Trans- mission
Axle Ratio
Payload
Base Weight
GCWR
Max Trail
4.7L V8 (EVE)
A5
545RFE (DGQ)
3.55
6,700
1,470
5,200
11,500
6,100
4.7L V8 (EVE)
A5
545RFE (DGQ)
3.92
6,700
1,470
5,200
12,500
7,100
5.7L V8 (EZD)
A5
545RFE (DGQ)
3.55
6,700
1,430
5,246
13,000
7,550
5.7L V8 (EZD)
A5
545RFE (DGQ)
3.92
6,700
1,430
5,246
14,000
8,550
Quad Cab 4x4 - SLT
Engine
Trans Type
Trans- mission
Axle Ratio
Payload
Base Weight
GCWR
Max Trail
4.7L V8 (EVE)
A5
545RFE (DGQ)
3.55
6,700
1,400
5,271
11,500
6,050
4.7L V8 (EVE)
A5
545RFE (DGQ)
3.92
6,700
1,400
5,271
12,500
7,050
4.7L V8 (EVE)
A5
545RFE (DGQ)
3.55
6,700
1,360
5,314
10,500
5,000
4.7L V8 (EVE)
A5
545RFE (DGQ)
3.92
6,700
1,360
5,314
11,500
6,000
5.7L V8 (EZD)
A5
545RFE (DGQ)
3.55
6,700
1,360
5,317
13,000
7,500
5.7L V8 (EZD)
A5
545RFE (DGQ)
3.92
6,700
1,360
5,317
14,000
8,500
5.7L V8 (EZD)
A5
545RFE (DGQ)
3.55
6,700
1,320
5,360
12,000
6,450
5.7L V8 (EZD)
A5
545RFE (DGQ)
3.92
6,700
1,320
5,360
13,000
7,450
Quad Cab 4x4 - LARAMIE
Engine
Trans Type
Trans- mission
Axle Ratio
Payload
Base Weight
GCWR
Max Trail
5.7L V8 (EZD)
A5
545RFE (DGQ)
3.55
6,700
1,610
5,063
13,000
7,750
5.7L V8 (EZD)
A5
545RFE (DGQ)
3.92
6,700
1,610
5,063
14,000
8,750
5.7L V8 (EZD)
A5
545RFE (DGQ)
3.55
6,700
1,570
5,106
12,000
6,700
5.7L V8 (EZD)
A5
545RFE (DGQ)
3.92
6,700
1,570
5,106
13,000
7,700
Read more: http://www.trucktrend.com/features/...uad_cab_tech_specs/viewall.html#ixzz2MJoL76kg
bigfink14
Junior Member
Ok just checked the Dodge web site, towing capacity is 9100# & payload is 14.000. The booklet I got with the truck with tow package had those larger numbers.
bigfink14
Junior Member
I checked the Dodge web site & found out my tow max is 9100#. Apparently I had bum info from a towing package book that came with the truck.
toyzrus
Junior Member
No problem, Now all you need to do is find your fifth, install your hitch and hit the road. You will not beleive the differance towing a fifth vs your tt.
