Towing with 1/2 ton
Yes this is the same post that I have posted many times in the past ... but ... if it will help one more person and maybe save someone a lot of misery, then I can put up with the flamers and critics..
So here goes ..... again
I believe that you will find most people saying "no-way" when they see a 1/2 ton truck trying to pull anything heavier than a 5000 lb trailer (wet weight).
And .. that 5000 lbs is the fully loaded and ready to go weight, with all your clothes, food, fuel, passengers, etc, etc... sometimes referred to as the "wet" weight. The average weight of the "stuff" that people usually take with them on their trip weighs about 1500 to 2000 lbs
It's not so much the trucks ability to tow the trailer as it is the ability to stop or/and maneuver in an emergency situation..
Yes, the trailer has brakes and should stop itself... but if the brakes are set correctly on the trailer they will engage a split-second or so AFTER the truck brakes engage.
With a light weight truck like the 1/2 ton, this could be dangerous. In that split second of time, the trailer could push the truck into a "jackknife" with the trailer.
Plus think of what will happen when going down a steep hill in the 1/2 ton with a 7000 or 8000 lb (and heavier) trailer pushing it from behind. You can't ride the brakes all the way down, it could cause a fire.
The combination of a 1/2 ton truck with any trailer over 5 or 6 thousand lbs (wet)can be a dangerous combination on the open highway at speeds of 60 plus mph and lots of hills and valleys to cross.
"air bags".. Some people don't seem to understand that adding air bags or air shocks or overload springs to a truck ... DOES NOT INCREASE ITS CARRYING OR TOWING CAPACITY.
The carrying capacity of any vehicle is directly related to the wheel bearings, axle, tires and rims..
If the rear axle is rated at ...just for an example,, say.. 2000 lbs, that’s the total amount of weight that the truck can carry .... including the truck's weight and no matter how many overload devises you install on the truck, it still will NOT carry more weight..
This not a put down on 1/2 tons, there is nothing wrong with a 1/2 ton pulling a trailer,,,, if it's within a safe weight...
I do sincerely wish everyone with a 1/2 ton truck the best of luck, and as I always say.. "it's just my opinion and everyone to his own"
John
