Trailer towing vs 5th Wheel
Kams, look in your owners manual, there is an exact formula for finding your true towing capacity. It will not match up with the tow rating shown. At least I hope your manual shows it. The manual for my new Ford F-150 does. I'll Try to explain , in case yours doesnt have it. Find your total Gross Vehicle Weight Rating (GVWR), Then take your truck to the nearest truck-stop and weigh your vehicle with the same amount of people in it that would normally be riding in the truck with you when you tow. Take this weight and subtract it from your GVWR. The weight that is left is the weight you can legally & safely tow. Keep in mind, that isnt saying it will pull that much weight up a steep grade at 50 mph! As Turkey stated, a steep grade will probably shut you down pretty hard. You will probably find after doing the math, that your true tow capacity is lower than the rating in your book. Mine was 6800lbs, after doing the math, I really only have 6640lbs that I can tow without exceeding my GVWR. Hope this info helps. :laugh:
