turn signals problem
fordman01
We picked up our 2003 class c coachman with E450 ford and thought we had checked everything and when i was on the road the wife tells me the turn lights are not working.there are many books and manuals with it but the ford owners manual is missing,wondering which fuse panel it is in,if that's the problem.
Re: turn signals problem
I don't know actually but sounds like the fuse panel would be in cab of the vehicle. I know Jenny and Randy (trytofindus) has the same unit. I hope they look in on the forum and see your post and can give you some insight.
fordman01
Thanks,there's a small panel under the dash and they are numbered but i don't have a diagram as to which covers what,there's also a larger panel under the hood.
then get a fuse tester from any auto part store so you can test each one in place. They do come in handy, as it can also pull the fuse out. And since it is a multiple tool, the Government will pay big bucks for it :laugh: :laugh:
try2findus
Hello all. Yes, our Jayco Greyhawk has an E-450 and our fuse box is located under the dash by the emergency brake area. I have a picture somewhere. If needed, let me know and I will try to take a photo of it and post it, but you should be able to Google it.
Hope you get those turn signals working and we'll see you somewhere along the way!
I'll be glad to copy and email you the pages that list the fuses if you need it. Let us know! :)
dfedora
Member
RE: turn signals problem
Denny
I have a 2005 RV that is on a 2004 Ford E- 450 chassis . Turn signal fuse, is fuse #7 10 amp 2nd row down from top 2nd fuse from the left. located as everyone stated to the right of emergency brake. Hope this helps.
