Used RV Solar Panel
burl
We are looking at a used solar panel as an add on with one we already have on our RV. However, the glass/plastic cover over the top (sun)side of the panel is shattered. When you test the panel with a tester, it is still generating power to the max but we are concerned about perhaps water getting into the cells and causing a problem. The owner said he had sprayed it with water recently, and had also used it for a year without a problem. We are wondering about it. Could the cover be replaced easily, would that be necessary, and if so what would you use. He said the dealer told him that since it was working there was no problem, and that this is not unusual. ???? What do you think? Thanks.
Poppa
Used RV Solar Panel
Second the motion pass :( . These units are sealed and most with and inert gas to prevent condensation from forming :dead: .
burl
Used RV Solar Panel
Thanks. This was what I was thinking but my husband wasn't sure.
Merry Christmas & Happy New year.
J
Used RV Solar Panel
If the cell is cheap enough, then you might want to get it and try making some typ of cover to protect it. But It would have to be no more than 10% of the same unit or equivilant, new.
