wall seperating
mikebough
I have a 2003 Fleetwood Providence. The problem I have been having is that when the sun hits the driverside of the motorhome the bathroom wall seperates about 3/8". It has done this since I bought this unit. The dealer did a so called fix on this as did the factory. The factory says that there will be some movement and that this is normal. I would like to know if anyone else has had this problem and if there is what did they do.
Mike
:angry:
wall seperating
No experience with this MH but will be interesting to see if other owners of the providence has this problem. Sure does not sound normal to me :eek: . Have you talked directly to someone at the factory? if the dealer and factory tried a fix they must not have though it was normal. Did you buy it new?
mikebough
wall seperating
C.Nash
I bought this MH new. I have had to take this back to the factory 4 times because the dealer could not or would not handle the many problems I have had with unit.
Mike
