Water got in between double pane window
rddog8691
Member
The class a bounder i purchased had some water get into the front drivers side and in between the two peices of glass in the drivers side window. The window is all foggy and dirty in between, has anyone ever had this type of problem and how would i deal with it.
Re: Water got in between double pane window
I believe they are the same as stick built in this regard and that means replacement. They are a sealed window and once the seal is broken nothing anyone can do.
Len is correct about the windows. They are two panes of glass that are sealed with a space between and charged with nitrogen. What eventually happens is that the seal leaks and moisture gets inside and about all that can be done is to replace the window, or the widow glass. In some cases you can get the glass replaced.
