Water heater winnebago Brave
mikel
I am a proud owner of a `97 Winnebago Brave 25" (this size is very big for Europe) and now the first Winter is coming, so i was looking for a valve to get the water out of the water heater, but I can not find one. Can anybody tell me how do I get my water out so it can not freeze. My old RV had one of those valve so I guess the Brave has one as well, or am I wrong??? :question: :question: :question:
rv wizard
It may not have a by pass vavle installed but you can use air pressure to blow the water out of the tank and lines. Simply hook up an air supply to the input for water and open all valves untill no more water.
fjohn56
Or find out if it has a drain plug at the bottom somewhere; not guareenteeing(sp)there IS one, but won't hurt to check.What rv wizard suggested will work, too.
Mike, there should be a screw in plug in the bottom of the tank below the burner for draining. Think it is about a 15/16 and most take a socket with an extension and pull handle (1/2"drive) to remove.
mikel
Thank you very much, those answers helped me a lot, thank´s again!
Mikel
