5thWheeler
Junior Member
It must be camping season again since there are several new threads and problems to fix. My current problem is with my water holding tank on my 5th Wheel trailer. It is a 50 gallon tank and when I fill it about 30 gals drains out of the overflow tube that is on the bottom of the trailer. I am not sure if the overflow tube is tapped into the tank on the top or the side since I didn't remove the underbelly sheeting. My first thought is that there is a siphoning effect taking place but I am not sure why. It is interesting to note that when the water is draining out of the overflow tube there is air being sucked into the fill nozzel where I attach the hose to fill the tank. So now I am thinking that the water tank is being pressurized somehow by drawing air from the fill nozzel. To confirm this I installed the rubber dust cap on the fill nozzel and the rate of water flowing out of the overflow tube slowed down significantly but didn't stop altogether.
To allow us to use the camper this weekend I installed a valve on the overflow tube to keep the water in the tank but I realize this is not the best solution because if I forget to open it when filling the tank, the tank could rupture.
Does anyone have any ideas as to what may be causing this problem? The water pump and all of the faucets are working fine.
Thanks in advance for any ideas someone may have.
5thWheeler
5thWheeler
