Pancanbob
Waterless Toilet - no holding tank - $850
SF bay area craigslist
Hi, All
I found this on Craig’s List, while looking at "RV for sell" :shy: :shy:
Has anyone had any experience with this? :question: :question:
Or is this one of those things…sound good, but doesn’t work in the real world
I used the “Search Forum†but nothing showed up there.
Just curious about it :blush: :blush:
Thanks :clown: :dead: :8ball:
Date: 2009-03-02, 5:50PM PST
Simple & Reliable
No Odors! This toilet separates the liquids from the solids (to put it politely), so it doesn’t smell bad. When the urine and solids are mixed, you get the really bad odors associated with sewage. When working properly the toilet has a slight earthy smell when you open it.
No holding tanks, no black water disposal issues!
This composting toilet is self-contained and waterless.
Efficient No Odors, No Clogging...... No Kidding!
No external plumbing, hoses or tanks to crack or leak. Uses 1½-2 gallons of peat moss in the base for composting the solids.
Compact & extraordinary holding capacity!
Because of the waterless, urine-separating design, this unit has extraordinary holding capacity. This could translate into a month usage by a cruising or traveling couple, or perhaps an entire boating or camping season of weekends.
"This toilet" is very compact and space efficient measuring 13" wide at the base, 17¾" front to rear, and is just under 20" tall. Despite it's small size it is very comfortable and stable.
— Plus! Easy installation in most applications, simply mount brackets to floor, vent unit to outside, and hook to 12VDC power source! (120 VAC & solar options also available.)
Eco-Friendly Completely Organic!
Our toilet is completely organic in that it uses no smelly or hazardous chemicals. The only thing you have to add to our toilet is peat moss.
This unit is made of an extremely durable polyethylene material and has a unique molded design,in a gray granite color. It corporate’s stainless steel components and hardware into a durable and low maintenance unit.
Hi, All
Simple & Reliable
