As I said above they old Sat antenna went under(well it still works in auto mode just won't get the sat I need. So with the choice of a new auto one for the roof(install would be EZ as all the wires are there and it would be EZ to pull more if needed) Or go with one of the portables. Well went with one of the portables CUBE type with it's own tripod. Had a receiver but brought home a new on just in case(as it is it will be going back) old one worked fine. Hooked up in less time than it took to get all out of the box and junk in the garbage. Took the cube maybe two minutes to find it self and off to the races. Worked great. Now I have 50' of cable with it and got an xtra 100 of power and rg6, don't know whether I'll keep these or not 50" is a long way to get out from under trees where we go. Thinking of running power to a bay and the cable so I have EZ access. OK $$$$$$$$ for the roof top was in the $1550 range and the cube was about $700, plus the tree thing so the choice was again EZ. Only down side is storing the antenna and cables(cables not a problem). So I may get/trade/make a quick detach roof mount and solve all the problems at once. OH and the signal was good and strong at the 47 degrees north where I am.
