krsmitty;82813 said:I towed my first TT with a 2002 JGCL (4.7). The TT was a Ameri-Lite 24', 5000lbs. The Jeep was rated to tow 10,000 pounds.
I WOULD not do again. IMHO the Jeep had to small of a wheel base for towing. Even with a WD/sway bar hitch the wind and semis moved it around quit a bit. Granted, you have the bigger motor, which would help in some ways. And I was using a bottom line WD hitch. The only way I would consider it is with a GOOD hitch setup, such as a Reese, Hensley etc.
