WHAT SIZE GENERATOR FOR RV
POOBEAR
JUST GOT MY 1 ST RV 34FT 5TH WHEEL THOR PARK AVE HAS A 13500 CENTRAL AC AND A 5600 SINGLE UNIT IN MASTER SUITE PLUS MICROWAVE ELEC COOK TOP FAN TV ECT SOMEONE TOLD ME TO GET A 5KW OR 5000 WATT UNIT LIVING IN TEXAS IN SUMMER IS REALLY HOT WHAT DO OTHERS USE
POOBEAR@MYLINUXISP.COM
JIM
How is the generator going to be attached? Is the trailer 'generator ready'? In that case, it should specify what generator(s) are appropriate. Are you going to just plug the trailer into it? In that case, it depends on what the main power rating of the trailer is. For instance, if the trailer is '50 amp' (which it probably is with 2 AC), then you would want a generator capable of putting out 50 amps, or about 6KW. I'm unclear how you would connect the 4 pin 50 amp plug to a generator, though...
