What TV mount is best?
Islandgirl
I have a 19" 15lb flat screen that I just bought for my house. This will be the tv floating back and forth from home to rv each weekend. What flat screen mount will be the easiest to move the TV back and forth between? I do not want a mount in the house and the RV that requires anything more than a slide and click (don't want to un-do screws, brackets and so forth). Does anyone have any suggestions?
*scooter*
Re: What TV mount is best?
A wall mount system is nice and can be used both in home and rv..but you must have an extra mounting bracket either for the home or rv. Using the wall mount bracket system in a rv will require you to mount to a stud like framing, which I don't if it exists in your rv. Just using the tv stand in both the rv and home means just lifting the tv to and from the rv to the house. Keep us posted on your findings..
Best of luck in your search :) :)
