Which truck for towing
quote:A half-ton 4x4 seems to be what I am hankering toward. Does the 5.9 liter have enough muscle? If we purchased a 3/4 ton with a 5.9 liter, would that have enough muscle? Should we go long-bed or short-bed?
For that much weight, I'd suggest the 3/4 ton based on my own experiences. I pull a race car on an open trailer with surge brakes weighing ~3700 pounds. Before I bought the current tow vehicle, I would borrow vans, throw a hitch and lights on them and go where I needed to go. The 150/1500 series vans, would warp their brakes at the start of the trip. Whenever I used the 250/2500 series vans, no problems with them at all, and the transmission was a lot less busy shifting. For my current tow vehicle, I went with a 2500HD and 4x4. Reason I went with 4x4 is so that I could use 4wd low and not waste my time spinning wheels in the wet grass. I also chose longbed, because it came with a much larger gas tank, compared with the shortbed. (at least for the GM models) For a 5th wheel, you should consider a longbed, unless you don't mind getting out in the rain to release the slider to back into tight spots or getting out to check the trailer to truck bed clearance. There are some people that are happy with their shortbeds, but in a longbed, you learn quickly where you can and cannot go. (you also learn three point turns, or flooring the gas in the wet.
Brian
Edited by - battmain on Jul 26 2001 3:17:50 PM
Edited by - battmain on Jul 26 2001 3:18:48 PM
