Will It Tow It O.K.?
Cgrmac1,
I have a few concerns about your proposed rig. First, I agree with Will, 4098lbs seems VERY light for a 31ft. trailer. You need to get that trailer weighed, with full propane, etc. I suspect that the weight you quote is the basic trailer, without microwave, battery, propane, awning, air conditioner, etc. etc. etc. Also, reducing the tongue weight that much is not necessarily a good thing. 10-15% is usually the minimum for a pull behind trailer for stability. More is better.
Second, you should definately get a transmission cooler and transmission temp guage installed on your truck. Heat kills transmissions and can build up very quickly, especially when climbing hills or backing up into a camping space.
Third, Your engine - rear axle combination is marginal. I have the same rear but a slightly bigger engine and it is barely adequate for my rig. Next time I will get a higher rear and probably a diesel truck.
Fourth, Keep your trucks GCVWR (Gross Combined Vehicle Weight Rating) in mind. By the time you put all your fuel,gear, passengers, dog, tools etc. in the truck - and then all your food, clothes, water, bedding, dishes, etc. in the trailer, - the whole thing combined must be under your GCVWR. I have a smaller trailer, my trucks GCVWR (a 3/4 ton)is 14,400 lbs and I just make it under by 1200 lbs according to the local CAT scale. The weights add up very quickly.
I would weigh your truck, get the proposed trailer weighed, do the math and then decide if your truck is capable of towing that trailer.
I hope I have not discouraged you but hate to see someone make a very expensive mistake. Good luck in whatever you decide to do.
Barney
1997 Sunnybrook 26CKS TT
1999 Dodge Ram 2500 quad cab, short bed, 5.9gas, auto. 3:54
1996 Harley Davidson FLHRI
Edited by - bsmith0337 on Mar 12 2002 9:54:20 PM
