Hello, i am not sure where to post this, so sorry if i am in the wrong place... i have a 2003 winnebago journey dl.. the problem i am having is with the WTEC III controller for the allison transmission...the shift pad will not light up at all..i have check the grounds at the controller plug and i do have a constant power on the trans power wire. if i put power to the "sensor power" wire at the plug i get the shift pad to light but not do anything. What should i be looking for...i am totally lost...thanks James
