Winterweather Rigs
MDThayer
Hi All,
I usually post in the Class C, thought I would change it up a bit. I am going to New Mexico at a week. All my tanks are exposed. I was going to purchase an RV Holding Tank Heater. Basically, a heating pad for my tanks. Anyone ever used one? Anyone have a suggestion. I was told to just use the "pink stuff" in the tank but it will become diluted when water is added to the tank.
Thanks, Diane
2000 Minnie Winnabago
2 Kayaks
1 Golden Retriever :)
Re: Winterweather Rigs
You are correct that anti freeze will dilute. Heating pads will work as long as you have the batter power to run them. Don't forget they are there and run your batteries down.
MDThayer
RE: Winterweather Rigs
Even while I am driving will it drain my battery? Once I am at the campsite I can plug them into an outlet. They are AC/DC plugs.
Thanks, Diane
2 Kayaks
1 Golden Retriever
Your battery should stay up when you are traveling as the coach battery does charge from the chassis alternator. The same should be true any time that you are connected to shore power, since the converter will supply the power.
I agree, while you are traveling, your battery will stay up. IF you stop overnight somewhere, like a rest area your battery can run down. What I was attemting to say is "be aware".
