jpeterman57
Does anyone have any experience with this generator? Mine has about 8 hours on it and when started will only run for a few seconds then smoothly shut off. It will not restart unless it sits for several minutes then the same thing repeats.
The spark plug is clean and dry when I pull it out to check. Spark is present. Though I don't know if it is sparking immediately after a shutdown.
I am suspecting the low oil shutoff switch though the oil level is fine and the low oil light does not come on when it dies and stops which gives me doubts. This switch does not look very accessible to try and bypass for troubleshooting.
Iunintentionalystored it a few months with unstabilized gas in the carb. I could smell the stale stuff when I was choking itup on the 1st start attempts. I drained the float bowl twice to make sure fresh was getting to it. These things auto throttle which I am unfamiliar with and don't know if that could be a factor.
Help.
Help.
