1993 Adventurer
Discussion in 'Talkback' started by p2top1, Nov 29, 2005.
  1. p2top1
    p2top1 New Member
    I'm new to class A.Does anyone have information or comments on this model.It is the standard run of the mill,with low miles,34rq.I noticed on the test drive a slight wander.Thanks,David P in Nashville
  2. Kirk
    1993 Adventurer
    Sounds like it probably has a GM, P-30 chassis? Adventurer is built by Winnebago and is their better quality gas powered motorhome. They have an excellent reputation. In 93 the GVWR would be 16K.
    What else do you want to know?
  3. Krazeehorse
    Krazeehorse New Member
    1993 Adventurer
    Wander could be worn front end parts, alignment, tire pressure or combination. Do the easy one first. Make sure they have enough air in the tires.
  4. p2top1
    p2top1 New Member
    1993 Adventurer
    Thanks Krazeehorse.I'vechecked air pressure,also air in F&R airbags.I'm going to run 75# in airbags.The front end is probably ok,the unit has 22,100 miles only.The tires might need balance though.Also,do you know where the furnace is located? I suspect its under dining booth floor.David
