2008 Keystone Laredo 272rl water leak
Discussion in 'Towables' started by o-pie, Apr 15, 2014.
  1. o-pie
    o-pie Junior Member
    I have a 2008 Keystone Laredo 272rl, when it rains I have water on the carpet next to the wall in the bedroom. There is no visible signs of where it is coming from, the walls are not wet. I have checked and re checked the roof and there is no damage. Anyone have any suggestions?
  2. C Nash
    Is there a slide where its wet? Start with a water hose wetting just small section at a time. Wait between wetting to see if it seeps in. Leak can come even from front. Most likely from window or top. Een though the wall is not wet it still can be coming down the side.
  3. dalenpalmer
    dalenpalmer Junior Member
    We need to find the complete detailed information about repair roof costs when we are planning for any repairs.
  4. C Nash
    Don't understand what you are asking? Do you want to know where you can get the cost for repair? What kind of repair? need more info. Welcome to the forum
  5. Isabella John
    Isabella John New Member
    First of all you should asked for a Roofing inspector for checking roof leaks, then use RV Liquid Roof for any damage or leak found. Thanks
  6. William David
    William David New Member
    You must consult with a good roofer for inspecting RV roof, EPDMRoofers is very reliable choice in my experience.
