5th wheel roof
Discussion in 'RV Tips & Tricks' started by dale24244, Apr 9, 2010.
  1. dale24244
    dale24244 New Member
    I have a 24ft fifth wheel and part of the roof is going to have to be replaced, even the plywood. Any advice how to go about it and what to use to put back?
    dale
  2. C Nash
    Re: 5th wheel roof
    Welcome to the forum Dale. What type roof do you have? You will have to remobe everything from the top AC, Antenna, vents and such. Remove side top mlds. Probably have to work from sides when possible or lay a good piece of plywood on top where working. You will probably find more damage than you think when you get into it. Need a inside area for this. Rubber roof will probably be easiest to go back with. I would replace the entire roof. Good luck
  3. dale24244
    Re: 5th wheel roof
    I am sure i will run into more then it looks like is there but with time and patients i think it can be done. Ive seen the rubber roof on the net but not seen anything on pricing for the Aluminum.
  4. C Nash
    Re: 5th wheel roof
    If you got the time and patients and $$$ it can be fun and rewarding Dale.
  5. dale24244
    Re: 5th wheel roof
    That is true.. it is all in what you make it to be. You can either dread it or enjoy it for the most part.
  6. cougarkid
    cougarkid Senior Member
    Re: 5th wheel roof
    Found this site the other day.
    Really good pictures and write-up of a do-it-yourself EDPM roof replacement.
    http://www.outerland.com/RV/index.cfm
    I am planning on doing mine this summer, along with side repairs, too.
