5th Wheel slide-out operations
Discussion in 'Suggestions/Comments' started by raplin, Aug 9, 2010.
  1. raplin
    raplin New Member
    How does 'one' open/close their slide outs on a 2003 Cameo LXI, F32RLS when there is a power problem; I can't find any access points for a handcrank?
  2. akjimny
    akjimny Senior Member
    Re: 5th Wheel slide-out operations
    Hi Robert and welcome to the RVUSA forum. I can't answer your question but you might re-post it in the "Towables" section where the trailer guys will see it. Ken from Grandview Trailer can probably help you with your problem. Good Luck!! :)
  3. Grandview Trailer Sa
    Hello there,
    You should be able to find a wrench socket or something close to that under the skirting on the opposite side of the slide. Not that familiar with Cameos, but they are all pretty much the same in the manual cranking.
