5th wheel vs travel trailer
Discussion in 'RV Tips & Tricks' started by The Utts, Apr 24, 2004.
  1. The Utts
    The Utts New Member
    I have a 2002 Chevy Silverado Z71 4x4 and we are trying to decide if we should be a Coachmen 26' lite 5th wheel or 30' Aerolite travel trailer. I have been reading about the advantages of the 5th wheel and my owners manual says I can toy 7800#, but will it really tow the 5th wheel or will I have problems?
  2. kbhilden@msn.com
    kbhilden@msn.com New Member
    Your vehicle should pull either trailer easily. The most important consideration is the LOADED WEIGHT.
    However, I pull a 5800# trailer with my 2003 GMC Savana Van with all wheel drive. This is only a half ton vehicle so I am limited to 6250#'s. I have the van because I must use a handicap scooter to get around. If not, I would have a pickup and tow a 5th wheel trailer.
    WHY? MOST OF THEM COME WITH GENERATORS OR CAN ADD A GENERATOR EASILY!!!. There is nothing worse than having a trailer and not being able to stop in a rest area or along a beautiful roadside vista because you can't plug in to power your A/C!!!
    So, I say; "Go for the 5th Wheel"!
  3. Gary B
    Gary B Senior Member
    Hi I have to disagree in that most 5th wheel do not have generators, most all motorhomes do. Only the very high end 5er have generators an then its an option, so with both a portable gen is the way to go and works equally with both. :) :laugh: :cool: :bleh: :approve:
