Re: advice on used travel trailer
ok ill tell you how im thinking about this, i was a welder aerospace ect, also i made parts for boeing and other companies, when you have a heated space like a trailer and it gets to 40 below moisture will acumulate in the walls, then your wiring gets wet and either shorts and causes a fire or with my trailer trips the archfault breaker, so i had to run all new wires in side the trailer. i cant afford a fithwheel cause i cant buy a special truk to haul it so i can only buy a travel trailer, i also went to school for elec engeneering so i need a travel trailer 29 to 34 feet with a metal or al frame complete then i will locate the frame members and rivet 3 inch honey comb strips on the out side of the frame around all windows and doors and cover the entire trailer in a second shell, then i will use closed cell insulating 2 to 3 inches thick to insulated, a lot of work but i can do it. kinda like aplying fiber glass to an old wooden boat. then ill modify the entire trailer for extreme cold living. sorry about my spelling, any way i need to find what trailers in the mid ninties were built with a welded metal frames or al walls and cielings. thank you
