Advise on tow vehicle.
Discussion in 'Hitches & Towing Questions' started by Gdean, Feb 25, 2014.
  1. Gdean
    Gdean Junior Member
    Buying jayco jayflight 32bhds 2014. Have ford f-150 supercrew v8 5.4L. With 3.15 RAR. Tow guide says tow max 8500 lbs. camper weight is listed as aprox. 8250 lbs.
    Some suggest adding air lift bags to. Suspension. Some say upgrade rear end axle ratio to 3.75 for 1100 lbs. capacity. Finally others say go to f250 super duty. Confused!
  2. C Nash
    Is the 8250 ULW? What is the loaded weight? Either way you are pushing your limit. IMO I would go with a F250. Where will you be towing? Short weekends, mountains or long hauls? Welcome to the forum.
  3. krsmitty
    krsmitty Senior Member
    X2...By the time you have the RV loaded you would be overweight big time. Time for a new TV. Then...might as well get a diesel :)
  4. akjimny
    akjimny Senior Member
    New truck time, for sure. You want to tow the trailer - not have the trailer pushing you.
