Allison Transmission Issue
Discussion in 'Class A / Diesel Pushers' started by starguy, Nov 3, 2015.
  1. starguy
    starguy Junior Member
    Sporadically, when our coach hits a major bump or expansion joint, it momentarially shifts into neutral and then back into gear,. The speedometer pegs as does the tach and several warning lights come on. At the same time, the odometer stops working! This might occur once every 50-100 miles depending upon the smoothness of the highway.
    I pulled the Medallion instrument cluster and added another ground in case there was a bad ground somewhere in the module. That had no effect. A local dealer's technician had a go at it but was unable to find the problem.
    Has anyone out there had a similar issue, and if so, what did you do to address it?
    Thanks for any help!
  2. Cindy Spencer
    Cindy Spencer Administrator Staff Member
    Hello Starguy - one of the Forum Members, AllisonMan, answers lots of questions like yours. I've sent him a message with a link to your post so that he can reply if he's able to.
    Cindy :)
  3. LEN
    LEN Senior Member
    Most likely an intermittent loose through the cabling. Just start looking at all the plugins for the shift console on back and reseat the connections(plugins)
