Atwood Water Heater Problems
Discussion in 'Talkback' started by ramosjac, Jun 29, 2002.
  1. ramosjac
    ramosjac New Member
    I have an Atwood DSI model water heater that doesn't ignite or enable the gas valve. I had the electronic board tested (tested good) and replaced both temp and eco switch. Still nothing! If I manually supply 12 volts to the eco switch, the gas valve opens, and then use a lighter to ignite the gas, I have heat. Has anyone seen this problem? Can I just bypass the electronic board for now?
  2. Gary B
    Gary B Senior Member
    Hi ramosjac, NO DO NOT bypass the circuit board, you'll have no safe gaurds. You have a bad circuit board, they sometimes test ok with a tester by will not work when installed. If you bypass the CB and the flame go out the LP gas will keep flowing. Get a Dinosuar board and give it a try. Good luck. DO NOT BY PASS THE saftey features. GB
  3. C Nash
    ramosjac, I can only echo what GB has told you. The only other thing that comes to mind, have you checked to see if you have current to the board? How old is the unit? Do not by-pass!!
    Chelse L. Nash
    fulltimer03@yahoo.com
  4. ramosjac
    ramosjac New Member
    Thanks for both your responses and advise. This is the second time I've been told that testers don't always identify faulty boards. That said: I'll look for a Dinosaur replacement board first thing Monday. No More Bypassing!
    P.S. I have current going to the board and the unit is 15yrs old.
    Thanks again,
    ramosjac
  5. Gary B
    Good thinking ramosjac, 15 years is problay the averave life of a circuit board. You won't go wrong with a Dino board. Happy trails GB
  6. Craig3fw
    Craig3fw New Member
    Hi All,
    I am perhaps a rare breed. We have a US RV in Ireland (28 foot and yes it does fit on Irish roads - just). Problem is an Atwood DSI water heater that fires up then cuts out. I have read that the electronics may be at fault. Any temporary quick fixes while I wait for a new board to cross the big pond ?
  7. JosephHuntley
    JosephHuntley Junior Member
    If you decide to get a boiler renewal, it is actually really quicker to obtain the help of the local professional that is truly knowledgeable with this sort of jobs. When it comes to gasoline boilers, water which is dripping may also be a result of blocked ports. Unblock stopped grills to eliminatethe seeping heater trouble. If your issue persists then contact any local plumber. At the time you've got an electric powered hot water heater,then boiler spills usually are due to heating element screws. Electricity heating elements might call for fitting a fresh gasket to eliminate hot fluids with leaking. When one learned that this water boiler seeping spot is originating through the piping, now have a look at this regarding plausible explanations. Loosened junctions for incoming cold water pipes for the boiler may be the reason of the outflow. Simply securing your pipe joints will ideally end your hot water boiler seeping on the underside.
  8. harleyman_1000
    harleyman_1000 Junior Member
    Can anyone tell me why on demand water heaters arn't used on rv's?
  9. C Nash
    Joseph, I hope the guy has his water heater problem fixed as his original post was in 02.
    Harleyman the only reason I can think of is maybe something to do with current draw. Sure some of the newer models with 220 service might use them. Maybe one of our electrical guru can answer this.
  10. big bilko
    big bilko Senior Member
    Hi Harleyman, I have a on demand LPG gas hot water installed on a relocatable home and it works perfectly.Made in China of course ,But only cost $130.Stainless steel cover and all connections came with it. All you need is a lpg bottle. 20 gallon output.I was so impressed with it I bought another for use at home. Regards BIG BILKO:triumphant:
  11. H2H1
    hey BB that post was started in 2002
  12. harleyman_1000
    Big bilko, can you send me the imfo on what you have?
  13. akjimny
    akjimny Senior Member
    Hey BB - send that info to me too. How's things "Down Under?" Are you and the missus coming back to the states any time soon? If you get up to Alaska, give me a call.
