Battery going dead
Discussion in 'General RVing' started by racefan, Sep 27, 2006.
  1. racefan
    racefan New Member
    Have 2 new optermir batterys that go dead after a couple weeks these are in 1995 carri lite 5th wheel with nothing left on any ideas???? sorry about spelling of battery names but i think you can tell the brand they are topf the line batterys :angry :( :(
  2. C Nash
    Re: Battery going dead
    Are you cutting the batteries off at the disconnect switch? If not it would be normal for the batteries to discharge in this length of time. There are several things that pull on them even though you turn everything off in the rv.
  3. s.harrington
    Things to check. 1. LP alarm(some cannot be turned off)
    2. Clock on stereo or monitor panel (cannot be turned off)
    3. CO alarm
    Though these don't draw much power, in a two week period it adds up. Get a battery disconect and install it between the battery and load. Get a 100/500 amp rated one.
  4. Kirk
    Most stereo clocks and all CO alarms draw power in the mili-amp range and would take momths to discharge a battery in good condition, but the LP alarm would do so if it is one that has a gas shut-off valve because the valves draw power to stay open. The easiest way to see if there is some phantom load that is doing this, just lift the negative cable from the post when you get back and monitor the voltage of the battery. If the voltage changes less than .5V in the two weeks, you have found the problem. The next thing is to locate the cause.
  5. DL Rupper
    RE: Battery going dead
    How about disconnecting one side of the battery when not in use. :approve:
  6. ARCHER
    ARCHER Senior Member
    I do that...disconnect when it is gonna sit for awhile without charging. I usually put the charger on coach battery just before I'm ready to start up....day before. Of course, I check fluid level and connections for any problems.
  7. Poppa
    Poppa Member
    Allthe guys are right, either disconnect a battery or install a disconnect switch 35 bucks worth.
  8. s.harrington
    I bought my battery disconnect switch(100 amp continuos 500 amp peak) at Harbor Freight Tools for $2.98. Its one of those with the little red plastic key. Works great.
