Battery Question
Discussion in 'RV Tips & Tricks' started by leon54173, Apr 29, 2018.
  1. leon54173
    leon54173 New Member
    We do a lot of dry camping and currently have 2 x 12v batteries in parallel. Batteries are approaching end of life and I’ll be replacing them shortly. I have the space for a third battery, and am thinking of going with 3 x 12v to maximize amp hours. However, I’ve never seen or read about such a configuration. Is there any reason I shouldn’t do this?
  2. In the Doghouse
    In the Doghouse New Member
    Leon-
    We have 4 deep cycle marines in our 5th wheel; no issues last year. As long as you hook them up in parallel and not series, you would be fine. The reasoning being that if they're in series, you end up with 24v system and anything with a max of 12v in your unit MAY get fried. The other thing you should do is hook pos. up to first battery and ground to last, which will drain all batteries equally
