Brakes on 1992 Prowler
Discussion in 'Towables' started by minky, Jul 16, 2007.
  1. minky
    minky New Member
    I just bought a 1992 21 ft. Prowler for $1000. I figured I couldn't go wrong. I'm a former pop-up guy. I assume that it has brakes. My 1999 Suburban has a tow package and has pulled my former heavy pop-up easily. Do I need a special braking box added to my Suburban? That's what the local trailer guy says.
    Also, what's the best stuff for fixing a leak around the air conditioner?
    In addition, is there a site that has all the specs for older trailers like this?
    Thanks.
  2. Bush70
    Bush70 New Member
    Re: Brakes on 1992 Prowler
    You will need a brake controler. That will control the trailer brakes. Is the A/C leaking inside? If so remove it and replace the gasket on the roof.
    Good luck
