Diesel fuel tanks
Discussion in 'Class A / Diesel Pushers' started by JEEPGUY, Nov 13, 2006.
  1. JEEPGUY
    JEEPGUY New Member
    I just moved from a class A to a diesel pusher. It's a 97 Monaco Windsor. When I fuel up I have a large amount of vacuum in the tank. Could I have a vent line plugged or is this normal.
  2. hertig
    Re: Diesel fuel tanks
    Where do you fuel? If I use the large nozzle/high speed pumps for 18 wheelers, it does not work well unless I just dribble it in at the lowest speed I can manage. Using a standard nozzle and speed (like at Flying J's RV island) works fine.
  3. hertig
    Also, my unit has a gas door on both sides, I unscrew both caps and that seems to help.
  4. JEEPGUY
    JEEPGUY New Member
    The vacuum is as I unscrew the cap. If I'm 50 to 60 gallons down it's really strong. I'm concerned that I could damage the Fuel pump since it's pulling so hard. Ever hear of this before? Thanks
  5. C Nash
    think this would be normal Jeepguy. Probably part of the emission system work. It pulls the fumes from the tank through the engine instead of venting to the outside air as we used to do. JMO
  6. JEEPGUY
    JEEPGUY New Member
    Thanks Nash, that does make sense.
  7. jroan
    jroan New Member
    RE: Diesel fuel tanks
    I don't agree with a vacuum being normal - I think I would look at the cap to see if it is the vented type or check to see if the system has a oneway valve that will vent the tank as the fuel is used but not let the fule escape except when excess pressure builds up and it vent the tank.
    I have seen the tank supply line leak at a coupled joint this joint is normal about at 1/2 tank and if that joint allows air from the tank to be sucked to the fuel pump however this will cause the engine to starve for fuel and quit.
    The vacuum could cause damage to the tank. I would check it out.
    Jroan
    Retired Navy
    Jackson MS
    2007 Tiffin Pheaton 40' DP
    2006 Honda CR-V Toad
  8. JEEPGUY
    JEEPGUY New Member
    Thanks Jroan, the cap looks to be a non-ventig type. I'll be searching out the ventlines and anything that could be plugged. thanks again for the tips.
