Re: engine removal 1989 class A winnabago
James, I looked at pictures of you motor home in the Internet and I don't see why you would have to remove the windshield. I would think it could be removed from the front, using either an engine hoist or fork lift. Or you could remove it a piece at a time. I know this is the hard way, but if you get it down to a stripped block, that should come out pretty easy.
By the way - why does the engine need to be removed??
