Re: External Radiator Cleaning
Yes I believe it is aluminum. Thank you for your input. Question, Seems that my cooling water flows from the top hose on the left side of the radiator, down to the bottom of the left side, then flows up to the top of the right side, down to the bottom of the right side then back to the engine. The reason I ask is, when I take a temp reading the top left is hot, bottom left is warm and the top right is cool and the bottom right is cooler. I have spoke with a radiator shop and they said that my right side could be plugged. I have a hard time believing this. What do you think. If the right side is plugged wouldn't I be getting hot all of the time. Right now I only get hot when climbing long steep grades. I will get up to 220 degrees which is only 5 degrees more than what CAT likes to see and 10 degrees below shutdown. :question:
:8ball:
