filling freshwater tank
Discussion in 'Talkback' started by purduepetewl, Aug 9, 2012.
  1. purduepetewl
    purduepetewl Junior Member
    I have a late 90's vintage fleetwood mallard bumper pull. 24 foot I believe. I am having trouble filling the freshwater tank. Problem developed recently. The tank will only accept a trickle out of the fill hose before it just "spits" the water back out. I assume this is a venting issue, but i cannot find any vent. Any ideas?
  2. akjimny
    akjimny Senior Member
    Hi Pete and welcome to the RVUSA Forum. Can you get to your water tank? Mine is under the bed and if I lift up the mattress and plywood, I have access to the tank. If you can get to yours, you can check your fill line and vent line for kinks or plugs, etc. If yours fresh water fill is like most, the vent line will be on the same fixture as the water fill.
    One problem I had last year was a mud dauber wasp built a nest in my vent line and plugged it up with mud. I had to blow it out from the inside out to keep from getting wasp baby in my water tank. You may have a simular problem. Good luck and I hope this helps some.:):)
  3. big bilko
    big bilko Senior Member
    Filling water
    I had a similar problem with my Coachman .Some bright spark took the knobs off the panel and put them on upside down.Check that the inlet is open as you will not get any water in.Might be a good idea to turn on a tap to make sure water is running. Regards BIG BILKO:)
