First RV
Discussion in 'Beginning RVing' started by ldworak, May 8, 2015.
  1. ldworak
    ldworak Junior Member
    I just bought my first RV. I have my first question. Should the water pump shut off after pressurizing the line. I used to have a pop up years ago and it did. I am not sure on newer designs. THANKS
  2. C Nash
    Mine shuts off when it reaches pressure. There is aadjustment on the pump. You may also have a leak if it is not shutting off. Welcome to the forum. What yr is your rv?
  3. ldworak
    Mine is a 99 Jayco Eagle 24
  4. akjimny
    akjimny Senior Member
    When you open a faucet or flush the toilet, the pump should run. When you shut the faucet off or take your foot off the flush lever, the pump should stop running after a couple of seconds, If the pump keeps running, the pressure switch on the pump needs to be cleaned and adjusted or replaced. Something after 15 years is keeping the switch from turning the pump off. Good luck with it. I hate plumping almost as much as I hate electrical problems.
