Flooring
Discussion in 'Full Timing' started by Cryzmath, Jun 14, 2006.
  1. Cryzmath
    Cryzmath New Member
    Greeting - It has been a long time since I've posted to the forum. My biggest question that I have at the moment is how can I change my floor in my rig? Currently we have carpet on the floor with foam padding underneath. I'm getting tired of vacumning all the time and I would love to change it to titles (with sticky back) or lamated wood.
    Any suggestions or tips on changing one's floor in the rig?
    Crystal & Shawn
    Fulltimers in Northwest Washington
    3 cats, 1 dog, 2 ferrets, and a bird
    36' Coachman Catlina (1995)
  2. Jeffatcc
    Jeffatcc New Member
    Flooring
    If the carpet is in front of a slide room, be careful about what you replace it with. Most slides will scar most hard flooring. You might get lucky and already have some kind of lanolium{sp} under the carpet and pad already. A call to Coachman might be in order. there # is 574-825-5821. Good luck.
    Jeff
  3. TexasClodhopper
    Flooring
    The only time I used (I was FORCED!) sticky-back tile on a floor, the stuff moved around after a few months of walking on it. We put it in a small bathroom, so there wasn't THAT much traffic. We ended up with gaps and bumps.
    Our Winnie is half linoleum and half carpet. The linoleum is what you walk on the most around the kitchen cabinets and back to the bedroom and between the shower and bathroom. Works great.
  4. Cryzmath
    Cryzmath New Member
    Flooring
    Well, we're lucky that our rig doesn't have a slideout. Jeff - thanks for the number for Coachman - I will put that into my book here at home. I assume that the "bumps and gaps" are related to the "wear and tear" on the titles?
    Thanks for the suggestions.
    :shy:
