Fresh Water Tank Issue
Discussion in 'General RVing' started by The Holks, Sep 13, 2006.
  1. The Holks
    The Holks New Member
    We have a 95 Bounder. To it we've attached a supply hose from city water (we do use a reducer and gauge) to our intake valve. Our fresh water storage tank is filling up automatically and we can't seem to get to stop! We replaced a valve located infront of water pump that when opened, allows water to fill the tank. Any ideas on why this continues to fill and how to resolve it?
  2. s.harrington
    Re: Fresh Water Tank Issue
    Some Bounders have a water tank fill valve between the city water inlet and the tank. Check and see if you have one and if you do turn it off. It is usually in a compartment near the tank and is usually labled.
  3. Poppa
    Poppa Member
    HMMMMMMM> You could install a check valve in the line from your tank o the pump. About any Ace or other hardware would have them in the plumbing section. :question:
  4. ARCHER
    ARCHER Senior Member
    Hello, Poppa,
    Missed ya around here for awhile..... :)
